9-3 tālās gunis
Melnais
9-3 tālās gunis
Post by Melnais »
Sveiciens, kolēģi! SAABiņš 9-3 izkrita TA un viens no diviem 2 bija par tālo gaismu neesamību. Lieta tāda, ka tālās gaismas sledzot, tas nefiksejas pozīcijā. Varu uzmidžinat, varu pievelkot un turot slēdzi braukt ar tālajām.. taču ieslēgt un atstāt nevar. Klikšķis ir bet gaismas nomidžinās un izslēdzas. Kad tikko nopirku bija arī tā , ka braucot tumsā tālās ieslēdzu, bet izslēgt nav iespējams bez galvenā sledža izslēgšanas. Izskatīju vairākus forumus un resursus. Pirms sākt kaut ko pirkt, varbūt te kāds ir saskāries ar šādu problēmu. Auto 9-3 1.8t wagons (2006) gada. Galvenais slēdzis ar gaismu limeņošanu ( atrodas pozīcijā uz 12tiem, auto gaisma). Būšu pateicīgs par padomu, kur skatīties ( relejs, pats slēdzis, blīve..?)
rzmzr
Re: 9-3 tālās gunis
Post by rzmzr »
The circuitry is quite complicated.
The headlamp switch is not connected directly to the headlamp. It's connected to the Body Control Module (BCM). The BCM is a microprocessor and relays and things behind the fusebox on the end of the dashboard, passenger side. You can see it if you remove the glovebox. The BCM generates the "lights on" signal on the car's computer network.
The computer signal is read by the instrument pack (Main Instrument Unit - MIU) which contains the blue light.
The stalk on the steering column sticks out of a big black box around the steering column. The box is the Column Integration Module (CIM). When you operate the stalk to turn on the main beam, or flash the headlamps, the CIM will generate another signal in the computer network saying "main beam on" or main beam off". This signal is read by the MIU to turn the blue lamp on and off.
That's the switch side. If the blue light is not coming on, I would suspect that the fault lies with the stalk or the CIM. The stalk can be removed by releasing a small hook underneath, just where it enters the CIM.
The lights themselves are switched by another unit, the "Underbonnet Electrical Centre" (UEC) which is the fusebox/microprocessor on the front left hand wing next to the battery. This unit reads the computer messages from the CIM, MIU & BCM and turns on the correct lights.
There is a known fault that the area under the UEC can get wet, The UEC can be unbolted and lifted out of the connectors beneath to check. But I wouldn't go this far before checking the stalk etc.
Slikti meklēji :)
Melnais
Re: 9-3 tālās gunis
Post by Melnais »
Paldies par informāciju, tiešām meklēju. No angliskā skaidrojuma sapratu, ka, ja tālo gaismu zilais signāls panelī deg ( tas arī deg, kad slēdzi pavelk), tad jāmeklē vaina zem kapota releju blokā.
